waldo63
#1 Posted : Wednesday, February 13, 2008 12:56:14 PM(UTC)
waldo63
How do I replace the hinges on the oven door? Can they be replaced from the front without taking the sides off?
#2 Posted : Thursday, February 14, 2008 12:15:04 PM(UTC)
In most cases the door hinge can be removed through the opening on the door frame.
Sometime the side panels have to be removed first.
Let me know if you'll need the instructions on how to remove the side panels.
- The part number for the door hinge (they are identical) is AP3868108.
Here are the break down diagrams for the Maytag range Model MER5730BAW
waldo63
#3 Posted : Thursday, February 14, 2008 12:38:50 PM(UTC)
waldo63
Thanks Gene. The hinges are on order. I'll let you know how I make out.
Waldo63
waldo63
#4 Posted : Friday, February 15, 2008 8:55:10 AM(UTC)
waldo63
Hinges replaced. They slipper right in from the front. Thank you very much Gene.
Waldo63
#5 Posted : Friday, February 15, 2008 9:48:01 AM(UTC)
I'm glad you were able to fix it.
How to replace hinges on Whirpool Oven door (Oven Repair (including Ranges and Cooktops))
by eileengor 7/3/2009 1:34:27 PM(UTC)
Im trying to replace hinges on a door (Oven Repair (including Ranges and Cooktops))
by fourfauls 1/7/2008 2:27:38 PM(UTC)
