Pgannon
#1 Posted : Friday, November 6, 2009 6:35:49 AM(UTC)
Pgannon
Whirpool Gas freestanding oven (SF387LEGW) experienced a power surge, and is no longer working. The display is blank, and the light does not come on when you open the door. I wasn't able to find a fuse. Using a voltage detector, power is making it to the board. Before I shell out the money, do I need to replace the control panel? If so, how do I find the part number?
Thanks for the help! This site is great!
#2 Posted : Friday, November 6, 2009 7:55:14 AM(UTC)
Replacement parts for sf387legw models | AppliancePartsPros.com
See Item 12 in Section 2
Here are the tech sheets
For W0 to W4
http://www.servicematters.com/d...0Sheet%20-%203196061.pdf
For W5 to W7
http://www.servicematters.com/d...0Sheet%20-%208272223.pdf
Here is a service manual which may come in handy.
https://secured.whirlpoo...5e3cea/$FILE/8178025.pdf
Since you have power at the board I would say it is toast.
