Hi all, I am Daniel. The igniter switched shorted out. I ordered new one, but they are very diffrent from the original part. The stem hole is larger, an will not turn with the stem. Please, let me know if I need to modify or what can I do to meke the replacement ones work. Thank you in advance.
Hi Daniel,
What is the part number of the switch you ordered?
What is the serial number of the range?
Thank Gene. Part WPL 12002788 Serial No. 16935060EA Daniel..
Daniel, This part number is incorrect. The correct part number for the ignition switch assembly for the range with these model and serial numbers is 12002790 which is Appliance Parts Pros Part number: AP4010264
Thank you Gene, hope you have a great day.
