layneskylar
#1 Posted : Thursday, November 5, 2009 9:39:57 PM(UTC)
layneskylar
I was using my oven earlier and I noticed that the heating element was not staying on. I turned my oven up to 450 F and it came back on. Now the element won't turn on unless the degree is 450 F or higher. Does anyone have any ideas what might be causing the problem or how it can be fixed?
#2 Posted : Friday, November 6, 2009 3:16:06 AM(UTC)
Cannot find any info on the given model number.
The unit may think that it already at a high temperature.
Check the oven sensor (se below) for resistance.
Also check that the sensor connector are clean and not corroded.
Here is a good link
http://www.applianceaid.com/elecrange.html
Check out 7, 8 and 21
If OK odds are high that the control is gone
