mdesai
#1 Posted : Thursday, November 5, 2009 6:24:01 PM(UTC)
mdesai
dishwasher would not start. when turned on and pressed STRAT button the, the "NORMAL" and "SOAK & SCOUR" ligts turn on but the dishwasher does not start? Any suggestions?
#2 Posted : Friday, November 6, 2009 1:36:10 AM(UTC)
Replacement parts for WHIRLPOOL GU2548XTPS7 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208572216.pdf
Sounds like you may have a keypad problem.
Also may be the control board
try to run the diagnostics.
Try the below connector cleaning
Check the keypad with a meter as both these buttons use P1-13 see the Page 2 of the tech sheet
Connector Cleaning
Kitchenaid Dishwasher Not Starting (Dishwasher Repair)
by willmt10 6/28/2020 4:22:06 PM(UTC)
Maytag Dishwasher not starting (has power) (Dishwasher Repair)
by End_User 8/8/2015 9:18:57 PM(UTC)
GE Monogram dishwasher not starting (Dishwasher Repair)
by woodygg 9/2/2013 11:20:45 AM(UTC)
Dishwasher not starting (Dishwasher Repair)
by Fzycrt2 5/15/2013 2:08:00 PM(UTC)
Maytag dishwasher not starting (Dishwasher Repair)
by aylmer 7/17/2012 9:37:38 AM(UTC)
dishwasher not starting, lights blinking (Dishwasher Repair)
by bowsher 1/27/2010 2:04:22 PM(UTC)
RCA Dishwasher not starting (Dishwasher Repair)
by tangent_man 11/25/2009 5:10:00 PM(UTC)
by FarmerGuy 9/23/2009 2:21:00 PM(UTC)
Start/Resume Light Blinking - Dishwasher Not Starting (Dishwasher Repair)
by DjPiLL 5/3/2009 12:57:57 AM(UTC)
Kenmore dishwasher not starting (Dishwasher Repair)
by hrmkr 7/9/2008 6:09:25 AM(UTC)
by ericeberry 1/7/2008 8:01:52 AM(UTC)
