J Justin
#1 Posted : Thursday, November 5, 2009 1:29:07 PM(UTC)
J Justin
Recently the bake element flamed/shorted out. I ordered a replacement element and installed it.
Here's what I have now:
-neither bake nor broiler element heats
-oven light works
-if I turn on oven at control panel, I hear the relay click open
-the cleaning cycle will lock the door
-but no heat
Took off the rear panels, do not notice anything wrong via visual inspection of connectors or the ECB.
What should I be doing to troubleshoot this? I have a multimeter and basic tools, no oven repair experience.
I have heard some people talk about the thermostat/hi limit thing being bad could cause this.
All help/instructions appreciated.
JJ
#2 Posted : Thursday, November 5, 2009 3:36:07 PM(UTC)
According to the wiring diagram there are no fuses or any other safety devices. With the new heating element and not broken wiring harness there is nothing else but a bad control board can cause such problem. It has to be replaced together with the overlay because it's glued to the clock.
- The control board (aka a clock/timer) Part number: AP3775600
- The overlay Part number: AP3791028
Here are the breakdown diagrams and Replacement parts for TAP TEF361ESC | AppliancePartsPros.com
