juliocvs
#1 Posted : Monday, November 2, 2009 11:04:21 AM(UTC)
juliocvs
I am trying to trouble shoot what "PF" means on dryer.
It will "Fluff", however it will shut off and display "PF" when heat is applied.
#2 Posted : Tuesday, November 3, 2009 5:25:41 AM(UTC)
Replacement parts for FRG LEQ7000EG0 | AppliancePartsPros.com
Here is the tech sheet which should help you trouble shoot it
http://manuals.frigidaire.com/p...r/134682200ts_wd_EFS.pdf
Run the error code check, see the tech sheet
Flip your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Better yet measure it with a meter
L1 to L1 should be 240 volts
L1 to Neutral and L2 to Neutral both should be 120 volts.
juliocvs
#3 Posted : Wednesday, November 4, 2009 10:19:51 AM(UTC)
juliocvs
It gave me a code of
FLd
017
E9E
When I put it in test mode it gave me a code of
E68
#4 Posted : Wednesday, November 4, 2009 10:53:22 AM(UTC)
Did you run it a couple times and get consistent results.
On problem with on board diagnostics is if the processor goes squirrelly, then so do the diagnostics.
So one indication that a board is bad is if the diagnostics give random results.
