AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
I didn't label which wire goes wher on the door switch
I didn't mean to disconnect the door switch wires so i didn't pay attention to where they go. the wire are red, which i know is the bottom wire because its bigger than the others. then there is a grey and a black wire. where do they go?
I cannot find a wiring diagram for this unit so all I can do is tell you how they are normally hooked up.
Common goes to the terminal block (power in) or the thermal fuse
Normally Closed goes to the interior lamp
Normally Open goes to the start switch or motor. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
