2 Pages<12
utzig
#11 Posted : Monday, November 2, 2009 10:50:08 AM(UTC)
utzig
Right. I had a bunch of ice because I bought coolers and bags of ice to keep food from going bad.
I am quite sure your problem is eithter the defrost heater (if you are getting frost build up on back wall of freezer.) or the control board.
Good luck.
SweetSwede
#12 Posted : Tuesday, November 3, 2009 9:42:39 AM(UTC)
SweetSwede
Thanks for your help on this. I ended up ordering a new motherboard, it will be here soon.
The fridge has a brand new defrost heater & thermostat already, that did not fix the evap.coil frost problem--I too am 99% sure now that its the motherboard. After this experience I will be hard pressed to ever buy a GE appliance again.
How is yours doing? running ok now? Motherboard replacement fixed the problem?
utzig
#13 Posted : Tuesday, November 3, 2009 10:37:13 AM(UTC)
utzig
All is working good now. I have had no problems since replacing the board.
Hope this works to fix your fridge.
SweetSwede
#14 Posted : Tuesday, November 3, 2009 11:20:24 AM(UTC)
SweetSwede
Glad to hear that gives me hope! Will post my progress..
Guest (6)
2 Pages<12
