I'm going to try to make this shorter than my previous post.
I had a problem with my fridge: alot of clicking. I replaced my old board Gea Part No 200D4860G015.
The replacement board given to me was Gea Part No 200D4850G013 and on the instruction sheet that came along it actually says Main Board WR55X10552 Single Evaporator and Single Speed Compressor Models with a note: "Do not use on dual Evaporator or variable speed inverter compressor models." How should I know what I have?
I replaced the old board and the fridge started working. It was working fine for about a month. 32 days. The warranty on the new board was for 30 days. What timing!
Then we noticed the freezer temperatue rising again. It reached 15 then 23, sometimes it would go back down to close to 0 F. Lately its been going as high to 30's. At first we thought maybe we didn't closse the doors proper, but it would happen too much. Even the fridge would warm up too to the low 40's.
Do I have a faulty new board? or the wrong board altogether? Or is there something else I should check? Currently the clicking noise is on a cycle. It would click; 8 to 14 seconds later it would click again, followed by another click at 145 seconds give or take 2; followed by another at 8 seconds or so, followed by another at 144 seconds; by another at 8 seconds or so; and so on and so on... I think its wierd, but what do I know?
You will need a meter to check things out, we are lost without meter data on this complicated refrigerator.
