AppliancePartsPros.com
Appliance Repair Help
Washer Repair
I can hear water behind the drum is this normal?
When I manually turn the drum I can hear water spinning is this normal or is it not draining properly? What to do if I want to repair it myself.
This is a good question and I have this problem. I guess no one knows the answer cause you didn't get any answer. Did you find out what the problem was and could you get back with me on the answer? Thanks djmarcel@mchsi.com
Maytag front loaders have a liquid in the ring of the inner tub to help balance the tub during spin cycle!
Matt.
Washer Repair
