LENNOX HVAC GAS VALVE MIGHT BE BAD. NOT SURE, OHM TESTED VALVE AND IT WAS 2.03Mohms. GETTING 28.43V WHEN SURELIGHT CIRCUIT BOARD SWITCHES IT ON BUT IT KICKS BACK OFF ALMOST IMMEDIATELY WHEN VALVE IS CONNECTED. VALVE IS A HONEYWELL MODEL# 60M1601, SERIAL# VR8205S2262. ANY HELP OR INSIGHT ON THE ISSUE WOULD BE GREATLY APPRECIATED.
