testiff
#1 Posted : Monday, November 2, 2009 8:23:05 AM(UTC)
testiff
:confused: WATER RUNS OUT THE DISPENSER CONSTANTLY. CAN NOT CUT IT OFF EXCEPT AT WALL AT THE INLET AND THE ICE MACHINE KEEPS CRUSHING ICE:cool::cool::cool::cool:
JLMoon
#2 Posted : Saturday, November 7, 2009 8:14:37 AM(UTC)
JLMoon
GE Profile with the same issue. Something is stuck making the water continue pouring out after cup is removed from the dispensing button. It started with just a small trickle after removing cup, but now it does not shut off at all. Before I take this thing apart, I'm hopeful that someone can let me know what I'm getting into.
testiff
#3 Posted : Monday, November 16, 2009 9:37:47 AM(UTC)
testiff
We still have not found the cause.
JLMoon
#4 Posted : Monday, November 16, 2009 10:00:27 AM(UTC)
JLMoon
Well I'm going to try to replace the inlet valve that someone else suggested as that seems to be the first place to check. If that doesn't work, I guess I'll then replace the electronics on the door. If something works, I'll let you know.
Qtip
#5 Posted : Monday, November 16, 2009 8:14:19 PM(UTC)
Qtip
Most likely replacing the water valve will fix the problem (noy positive on this as the ice maker continuously crushing ice sounds like a seperate problem but the water not stopping is a very good indication of a bad water valve
Guest (5)
