I put a normal sized load into the washer and the water just kept coming. I turned everything off, turned the machine (only) back on to complete cycle and drain then turned water back on and it stopped like it should've the first time. What caused this to happen and what do I do to prevent this from happening again?
Rank: Administration
Groups: Administrators
