AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Freezer Evaporator Icing Up/refrigerator Warm/fan Runs Continuously
My Freezer Keeps Icing Up And Cool Air Quits Going To The Refrigerator (fresh Food Side). I Also Noticed The Fan By Compressor Is Running Continuously. I Turn It Off And Let Everything Melt And It Works Again For About 24 Hours. I Noticed I Can Order Parts Directly From Applianceparts.com. How Can I Fix This Problem?
Here are your parts Replacement parts for MAYTAG MSD264RHEB | AppliancePartsPros.comHere is a tech sheet and a manual http://www.servicematters.com/m...ibrary/docs/16026204.pdf http://www.servicematters.com/m...ibrary/docs/16025628.pdfDoes sound like a defrost problem but only running for 24 hours seems a short amount of time. I would check the door seals/gaskets. Take a dollar bill, put it betwee the door casket and the frame and pull it out. Work your way around the door. If the bill pulls out with no resistance there is a problem. Remove the evaporator coil cover. If the coils are iced/frosted up to the point that the fan cannot pull air through them, then it is a defrost problem. Force a defrost cycle, see the tech sheet. If the defrost heater heats up then the adaptive defrost control needs replacing (Item12 Section 4)♦ Be careful that you do not burn your fingers. If it does not heat up then odds are it is either the defrost element or thermostat, see Section 7. Undo the element and check it with a meter, should be about 30 ohms Remove one wire from the thermostat and check it with a meter shopuld be 0 ohms when frozen. Note that it opens just above freezing so be sure it is frozen. |
THIS FORUM IS DEAD!!!!!!! |
