hdavis
#1 Posted : 15 years ago
hdavis
MY wife was changing the bulb under the unit with the power plugged in. Touched the bulb, which was cool, and tried to un screw it. The bulb came out of its socket and she heard a pop. The pop I assume is the gas releasing from the bulb. I unplugged the unit, replaced the bulb and there is no signs of life on the unit. I checked breaker panel (ok), I replaced fuse in unit (ok), there is power at the outlet, but nothing at all comes on when the unit is plugged in??????
#2 Posted : 15 years ago
Check the cavity thermostats for continuity (location shown in the Tech sheet). Probably you have to remove the microwave from the cabinet to access them.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL MH1150XMB3 | AppliancePartsPros.com
tejacobs11
#3 Posted : 15 years ago
tejacobs11
I just had the same thing happen to me on this morning. the model is MH1150XM. However the fan will go on high, the key pad works. When you start the microwave the clock will turn on and count down however the microwave will not work. Is there anything particular that needs to be replaced, can it be reset or what. I hate to have to go by a new one.
#4 Posted : 15 years ago
Remove the top grill and open the control panel. Check the door switches and how they are engaged when the door is closed.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL MH1150XMB0 | AppliancePartsPros.com
