My Sanyo over-the range microwave has no power at all this morning. The wall electrical outlet is working fine. What do you think has caused this?
The problem turned out to be a 20 amp fuse that I was able to replace and the unit is working fine. Sometimes a blind squirrel finds nuts.
An update-the unit just died again. What is the most likely thing to be forcing the fuses to go?
My sanyo em-s8000W did the same thing. Where did you find the 20 amp fuse?
