jreich77
#1 Posted : Sunday, November 1, 2009 4:33:01 PM(UTC)
jreich77
my dryer hont heat up. it turns on but therte is no heat!
#2 Posted : Monday, November 2, 2009 12:25:32 AM(UTC)
Replacement parts for WHIRLPOOL LEQ9030PQ0 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208528187.pdf
First try flipping your breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker. Better yet measure it with a meter should be 240 volts. On this unit if the timer advances in timed dry, you have the 240 as the timer motor uses 240.
Next unplug the unit and check the heating element, the thermal cut-off, the hi-limit thermostat and the operating thermostat.
Guest (4)
