ray1tree
#1 Posted : Sunday, November 1, 2009 6:54:06 AM(UTC)
ray1tree
wire hanging inside of fridge got caught up on water pitcher and broke off stopping unit completely can this be fixed
#2 Posted : Sunday, November 1, 2009 8:44:17 AM(UTC)
Here are your parts.
Replacement parts for RNB19AN3A models | AppliancePartsPros.com
Cannot say if it is fixable, the description is a tad brief,
Follow the wire back to where it goes and you should be able to figure out what it is for.
Should not be a big deal to fix unless it pulled apart where it goes down the back of the machine.
ray1tree
#3 Posted : Sunday, November 1, 2009 11:22:01 AM(UTC)
ray1tree
it goes to the thermostat
#4 Posted : Sunday, November 1, 2009 3:51:41 PM(UTC)
Take a look at Item 12 In Section 3 of the parts (thermostat)
It has 2 wires connected ti it's contacts. These are standard wires with connectors on the ends.
It also has the capillary tube, this is the actual sensor and if this is what has been pulled off you will have to replace the thermostat.
Click in the picture of the thermostat and a new page will come up with more views.
