The washer will agitate while filling. It appears that it goes through the cycles. The timer dose move the dail. The problem started when the machine finished and there was still alittle water left in the tub. I tried to finish the load on a different cycle. I am not sure if it is the timer or something else. Can someone help? rowejo
