vanbao
#1 Posted : Saturday, October 31, 2009 3:28:12 PM(UTC)
vanbao
I range is displaying the F30 error. I did some research and found out that this error might be a result of a bad themo sensor.
I would like to know how to test to see if the thermo sensor is good and where to locate this sensor on the unit.
Thank you in advance.
vanbao
#2 Posted : Saturday, October 31, 2009 7:47:29 PM(UTC)
vanbao
Update,
I took my ohm meter and measured the swicth, thermal cutoff that is connected to the oven temperator sensor and there is no ohm at at. Normally, is there a way to find out if this switch should be in a closed or open position under normal circumstances.
Thank you.
#3 Posted : Sunday, November 1, 2009 4:38:16 AM(UTC)
Normally thermal cutoffs should be 0 ohms at room temperature.
An exception is a fan thermostat, it closes at a certain temperature to turn the fan on
Here is your wiring diagram in case you do not have it
http://manuals.frigidaire.com/p...assomption/318271934.pdf
