Dad2Boys
#1 Posted : Friday, October 30, 2009 1:10:36 PM(UTC)
Dad2Boys
Hello,
We have an Amana ACF4255AW and the door doesn't close properly. I typically have to lean into it to make sure the light goes off during cooking. Also, when we ran the cleaning cycle, it actually melted the inside black trim piece.
Should we replace the springs and the trim piece or just call someone to look at it?
Thanks!
#2 Posted : Friday, October 30, 2009 3:23:06 PM(UTC)
You probably have to replace the door hinges together with the hinge receivers (#19 on the diagram). I'm afraid I did not get clear which trim did you mean. Can you refer to the diagram?
Dad2Boys
#3 Posted : Friday, October 30, 2009 5:34:01 PM(UTC)
Dad2Boys
I think it is this part: AP4041612. I ordered from this website a couple of months ago when it happened. We thought it was just that piece, apparently we were wrong.
Thanks!
Michelle
#4 Posted : Sunday, November 1, 2009 4:12:00 PM(UTC)
Michelle,
If I got it right, you replaced this maintop bracket (#11 on the diagram) but it did not solve the problem?
Dad2Boys
#5 Posted : Sunday, November 1, 2009 4:17:01 PM(UTC)
Dad2Boys
yeah, we thought it was the problem, but apparentley it is either a hinge or spring?
#6 Posted : Sunday, November 1, 2009 9:17:51 PM(UTC)
Spring is a part of the door hinge. Besides the door hinge or the hinge receiver it could be a slightly bend inner door layer or he door frame. I can only guess. The hardest part is to properly diagnose the problem and only you can do it because we can not see it.
Dad2Boys
#7 Posted : Monday, November 2, 2009 2:49:39 PM(UTC)
Dad2Boys
Thanks. I really think it is the hinge/receivers. This was the other part (the one that melted AP4041769) It is white and black. It is a trim top piece.
How hard is it to change the receivers?
Thanks!
#8 Posted : Monday, November 2, 2009 3:07:04 PM(UTC)
Quote:
...How hard is it to change the receivers?...
You have to pull the range out of the wall and remove the side panels.
Guest (6)
Problem with my oven door not closing (Oven Repair (including Ranges and Cooktops))
by REV1842000 6/7/2012 4:52:28 AM(UTC)
Oven door not closing properly (Oven Repair (including Ranges and Cooktops))
by irasend 1/13/2010 10:49:21 AM(UTC)
Oven Door not closing tightly (Oven Repair (including Ranges and Cooktops))
by manager3 7/31/2009 7:21:59 AM(UTC)
Oven Door Not Closing After Hinge Replacement (Oven Repair (including Ranges and Cooktops))
by seury1 5/18/2009 12:57:33 PM(UTC)
oven door not closing completely (Oven Repair (including Ranges and Cooktops))
by wmpalovick 4/8/2009 12:33:11 PM(UTC)
by chefdancan 10/21/2008 2:08:23 PM(UTC)
