moose1959
#1 Posted : Thursday, October 29, 2009 6:02:16 PM(UTC)
moose1959
I have a ge over the counter microwave, jvm1430wd002.
everything seems to work except no heat
SublimeMasterJW
#2 Posted : Friday, October 30, 2009 5:31:52 AM(UTC)
SublimeMasterJW
Electricity from the wall outlet travels through the power cord and enters the microwave oven through a series of fuse and safety protection circuits. These circuits include various fuses and thermal protectors that are designed to deactivate the oven in the event of an electrical short or if an overheating condition occurs.
UserPostedImage
Generally, the control system includes either an electromechanical relay or an electronic switch called a triac as shown in Figure 2 . Sensing that all systems are "propah," the control circuit generates a signal that causes the relay to activate, thereby producing a voltage path to the high-voltage transformer .
UserPostedImage
In the high-voltage section, ( Figure 3 )
UserPostedImage
the high-voltage transformer along with a special diode and capacitor arrangement serve to increase the typical household voltage, of about 115 volts, to the shockingly high amount of approximately 3000 volts! The microwave energy is transmitted into a metal channel called a waveguide , which feeds the energy into the cooking area where it encounters the slowly revolving metal blades of the stirrer blade . Some models use a type of rotating antenna while others rotate the food through the waves of energy on a revolving carousel. In any case, the effect is to evenly disperse the microwave energy throughout all areas of the cooking compartment. Some waves go directly toward the food, others bounce off the metal walls and flooring; and, thanks to special metal screen, microwaves also reflect off the door.
So, the microwave energy reaches all surfaces of the food from every direction.
When the door is opened, or the timer reaches zero, the microwave energy stops--just as turning off a light switch stops the glow of the lightbulb.
So, when all systems are Go, with the door is closed, an electrical path is established through a series of safety interlock switches and extends voltage onward towards the thrusters of this bad boy.
UserPostedImage
typical voltage doubler
UserPostedImage
voltage doubler to the magnetron
The transformer secondary (output) voltage swings into the negative half-cycle and increases in a negative direction to a negative 2800 volts, with polarities as shown. The transformer secondary and the charged capacitor are now essentially two energy sources in series. The 2800 volts across the transformer winding adds to the 2800 volts stored in the capacitor and the sum voltage of 5600 volts is applied to the magnetron cathode. There are two fundamental characteristics of this 5600-volt output that should be noted:
First, because a voltage doubler is also a rectifier, the output is a DC voltage.
Second, the resulting output voltage that is applied to the magnetron tube is actually a pulsed DC voltage.
This is because the doubler generates an output only during the negative half-cycle of the transformer's output (secondary) voltage. So, the magnetron tube is, in fact, pulsed on and off at a rate of 60 times per second here in the good old U S of A.
