slavik1953
#1 Posted : Thursday, October 29, 2009 6:40:16 PM(UTC)
slavik1953
Error code F 5
#2 Posted : Friday, October 30, 2009 1:59:41 PM(UTC)
The "F5" error code means "Intermittent oven temperature sensor or bad main relay board". The recommended corrective action is "Replace the oven temperature sensor. If control still displays F5, replace main relay board."
Unfortunately the main relay board has been discontinued by the manufacturer and is no longer available.
- The oven temperature sensor Part number: AP2831584
Washer error code F 51 (Washer Repair)
by anmika 11/1/2011 6:22:53 AM(UTC)
Oasis kenmore code F 50 appeared (Washer Repair)
by lyzzzyl 9/15/2009 9:04:58 PM(UTC)
