scottwest
#1 Posted : Wednesday, October 28, 2009 8:00:13 AM(UTC)
scottwest
while washing time will blink after 3 to 5 times F6 code. can cansul and drain and spinn with all speeds befor going out on F6. had repaire man out said it was a speed signal problem could be wire harness, motor, main computer bord. I replaced cheepest $ 70.00 wire harness, did NOT work. any ideas.
sidfink43
#2 Posted : Thursday, October 29, 2009 4:02:29 PM(UTC)
sidfink43
These are great machines, but when they have problems it is pretty difficult to diagnose the source.
Use this service manual to test out those components and see if you can determine which one is the problem.
https://secured.whirlpoo...ILE/Duet%20Job%20Aid.pdf
scottwest
#3 Posted : Tuesday, November 10, 2009 9:46:19 AM(UTC)
scottwest
before i bought a used main bord I called sears and checked the part numbers, they said they were the same even know the ours was 400 and theres was 401. The machine will fill for 45 seconds then shut down, bad flow meter. We do not have a flow meter in our rubber water line, is it posibale that the bords are difrant even know sears says no.
scott west
