gcsterry
#1 Posted : Thursday, October 29, 2009 12:13:06 PM(UTC)
gcsterry
How do I replace oven door hinge receivers and hinges?
#2 Posted : Thursday, October 29, 2009 3:47:17 PM(UTC)
The door hinges are inside the door. You have to remove the door from the oven as described in the Owners guide (page 14). Put it on a flat surface with the door handle facing down. Remove the screws holding the inner door liner and remove the liner.
In order to replace the hinge receivers you have to remove the oven from the cabinet and remove the side panels.
- The LH door hinge Part number: AP3861924
- The RH door hinge Part number: AP3851097
- The LH hinge receiver Part number: AP3136118
- The RH hinge receiver Part number: AP3136119
Guest
#3 Posted : Friday, December 1, 2023 3:17:22 PM(UTC)
Guest
Rank: Guest
United States
