bflartey
#1 Posted : Thursday, October 29, 2009 5:03:06 AM(UTC)
bflartey
I'm having a problem with frost. I had a repair man open the freezer and claim I probably need a defrost heater. I found a part for my model called heater + bracket part # AP 3183311. Is this hard to replace? and is this where I should start?
SweetSwede
#2 Posted : Thursday, October 29, 2009 5:28:41 AM(UTC)
SweetSwede
You can put your refrigerator model number in the "Search the Appliance database" field above--click on the freezer section on the left it will pull up a parts breakdown and show their location. It should be located behind a panel in the back of the freezer, panel attached by probably 4 screws, the heater itself will likely be at the bottom of the evaporator coils. Easy to replace--2 wires and 2 screws.
bflartey
#3 Posted : Thursday, October 29, 2009 6:15:19 AM(UTC)
bflartey
Should I start by replacing the heater + bracket?
SweetSwede
#4 Posted : Thursday, October 29, 2009 11:31:02 AM(UTC)
SweetSwede
You need to check the continuity of the heater to determine if it is good or bad--use a multimeter set to X1 to measure ohms--should read about 22 ohms I believe if good. Read the 1st page of the sticky in this forum titled "Freezer is fine, refrigerator too warm", Gene has an excellent explanation of how to troubleshoot defrost problems.
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Freezer coil frosting up Whirpool wrb322dmbm00 (Refrigerator & Freezer Repair)
by rockrguy182 8/1/2020 9:47:21 AM(UTC)
Whirlpool fridge ice maker frosting up (Refrigerator & Freezer Repair)
by TomDavis 11/20/2017 1:41:32 PM(UTC)
Non-defrosting upright freezer not cold on bottom (Refrigerator & Freezer Repair)
by KOP264 6/12/2017 4:38:01 AM(UTC)
Samsung ice maker frosting up (RF28HDEDBSR) (Refrigerator & Freezer Repair)
by Winchester30 6/5/2017 4:17:32 AM(UTC)
Samsung Drawer freezer is frosting up (Refrigerator & Freezer Repair)
by deserttom 9/12/2013 3:21:47 PM(UTC)
Icemaker dispenser is frosting up (Refrigerator & Freezer Repair)
by McDani 7/11/2013 2:13:08 PM(UTC)
freezer frosting up (Refrigerator & Freezer Repair)
by hammerman 2/11/2013 9:40:51 AM(UTC)
Evaporator Coil Frosting Up (Refrigerator & Freezer Repair)
by George Wagner 7/2/2012 1:23:45 PM(UTC)
Frosting Up And Not Cooling (Refrigerator & Freezer Repair)
by rgirrbach 3/1/2010 6:13:09 AM(UTC)
Kenmore refrig frosting up coils in freezer compartment (Refrigerator & Freezer Repair)
by js7865 12/21/2009 9:11:23 AM(UTC)
Freezer frosting up (Refrigerator & Freezer Repair)
by davidlubb 11/26/2009 4:10:50 AM(UTC)
Freezer frosting up & getting warm (Refrigerator & Freezer Repair)
by mesteph 5/30/2009 2:16:10 PM(UTC)
by lkquigley 4/14/2009 3:00:27 PM(UTC)
Freezer/Top of fridge frosting up (Refrigerator & Freezer Repair)
by Ride4lifeCBR 3/18/2009 8:51:02 AM(UTC)
