Tennessee Tom
#1 Posted : Thursday, October 29, 2009 2:41:45 AM(UTC)
Tennessee Tom
The ice dispenser and water dispenser arms don't want to shut off after use. For instance, after filling up a glass of water you pull the cup out and the arm slowly lifts back up. By the time it shuts the water off you can almost fill up another 8 oz. cup! The ice dispenser does the same, you take your cup out and the ice keeps coming until you manually shut it off! I started to investigate but I became leary when I couldn't get the front trim piece off...one of those things I'm sure there is a trick that makes it simple, but that I always manage to break because I don't know the trick! I would apprecaite any help I can get, Thanks!!!
