scottyboy
#1 Posted : Tuesday, October 27, 2009 2:05:32 PM(UTC)
scottyboy
the wiring clip connections were corroded off.replaced connections but need to make sure they are attached properly.4 wires,red,orange,green&gray.2 upper poles&2 lower poles on relay.
sidfink43
#2 Posted : Wednesday, October 28, 2009 12:45:56 PM(UTC)
sidfink43
Hi Scotty
GE does not make its technical infor available, so we are not going to know the answer to your question.
You should have tech notes and a wiring diagram inside the console. You are going to have to use that diagram to trace the wiring and make the right connections.
scottyboy
#3 Posted : Wednesday, October 28, 2009 2:10:01 PM(UTC)
scottyboy
sidfink43;thanks anyway 4 reply.think i solved by trial &error plus just found original manual.amazing after 12yrs,dryer next!thanks again SCOTT!
sidfink43
#4 Posted : Wednesday, October 28, 2009 2:42:42 PM(UTC)
sidfink43
Great, glad you could work it out. Now if you can just get GE to let us have info so we can help folks like yourself.
Thanks for the update.
