I am having trouble with the heat in my dryer. The dryer itself works fine. It started about 3 months ago with the dryer giving no problems at all. Now the heat seems to work intermittent. After changing out the relay control, a load of towels were put in the dryer. After 120 minutes they were still damp....Can't seem to pin it down. I think the heat element is coming on but not sure for how long.....
1. checked the vent for clogging 2. 240 volts is being supplied to system 3. checked continuity of sensors 4. dryer coil reads 10 ohms 5. replaced the relay control (165.00 part)
THIS FORUM IS DEAD!!!!!!! |
