socalmat
#1 Posted : Tuesday, October 27, 2009 12:26:21 PM(UTC)
socalmat
Hi
I have a pdr486gdz/06 thermador range with an electric oven. The lower heating element is not working on the larger oven.
I replaced the heating element and that did not fix it. Then I shut the power off for several minutes with no help.
Also, I recently replace the circuit boards in the back to fix a different problem and it has been working normally until recently.
What now?!
Thanks for the help
Matt Winter
socalmat
#2 Posted : Wednesday, October 28, 2009 12:03:06 PM(UTC)
socalmat
No one responded and because it is difficult to find help on any Thermador product i decided to check my wiring job. it turns out that i had two wires switched on the new circuit board. No it is working again. If you have the same range and would like information on switching out the old and new circuit boards or heating elements, drop me an email at mawinter@cox.net
