aace73
#1 Posted: : Wednesday, February 6, 2008 5:56:56 PM(UTC)
aace73
Hi All,
Dishwasher fills can hear pump turn on after fill but wash arms are not moving. It will drain itself with out problem.
#2 Posted : Wednesday, February 6, 2008 6:20:29 PM(UTC)
Open the door after the pump engaged and check the water level and if the spray arm is spinning.
Post your findings.
aace73
#3 Posted : Wednesday, February 6, 2008 6:36:34 PM(UTC)
aace73
No not moving the dish's are dry and the motor is running. Hmmmm....
Thanks again
#4 Posted : Thursday, February 7, 2008 5:15:31 PM(UTC)
Most likely the problem is a bad pump which has to be replaced.
- The part number for the pump & motor assembly is AP3160640
Here are the break down diagrams for the White Westinghouse dishwasher Model MDB124BHS0
