kight57
#1 Posted : Monday, October 26, 2009 6:52:29 AM(UTC)
kight57
Used hotpoint dryer makes high screeching noise when used. Noise dies down for a little bit & then it's up high again. Could it be a bearing that's going out? Any suggestions would be very welcomed!
#2 Posted : Monday, October 26, 2009 3:24:24 PM(UTC)
Most likely the problem is a bad rear bearing. I would check the front glides as well. The model number you posted does not come up. Verify and repost it.
mnollett
#3 Posted : Thursday, December 31, 2009 6:54:10 PM(UTC)
mnollett
That model is more like 25 years old, I agree with Gene, rear bearing or front glides
