spurcell
#1 Posted : Saturday, October 24, 2009 4:58:00 PM(UTC)
spurcell
I have a Bosch Nexxt 6300 washer. It gave an error
message like "clogged drain" last time I used it. Has
anyone ever encountered this problem? Where should
I start to look for the problem? Many thanks....
sidfink43
#2 Posted : Sunday, October 25, 2009 11:31:58 AM(UTC)
sidfink43
Those of us who reply on this Forum do not have experience on this brand, so I am going to recommend you post on another Forum and see if you can get some help.
Good luck.
spurcell
#3 Posted : Sunday, October 25, 2009 11:59:21 AM(UTC)
spurcell
I appreciate that info...if only I knew of a forum where Bosch folks *do* hang. If anyone knows of one, please share. Thanks.
I poured some bacteria cleaning stuff down the pipe last night and cleaned the outside of the hose, which had cat hair and lint stuck to it, indicating that the problem might be a simple clog in the pipe from my dear cats' coat and lint from blankets. So far i've been able to run two loads OK this morning. I will continue to pour nontoxic cleaners down the pipe because I do blankets often (long-haired cats in the family).
sidfink43
#4 Posted : Sunday, October 25, 2009 12:38:40 PM(UTC)
sidfink43
Well, glad you have it running, at least for a while.
We are so used to error messages not being useful or not being a correct diagnosis that we are occassionally too cynical about one like yours. Who knew clogged drain meant clogged drain?
