wuba
#1 Posted : Saturday, October 24, 2009 9:22:37 AM(UTC)
wuba
My freezer just stopped working. I have check the curcuit breaker, outlet and power cord they are all ok. What should I check next?
Thanks for your help.
delphino
#2 Posted : Friday, November 6, 2009 5:15:36 PM(UTC)
delphino
Try unplugging the freezer for about four to five hours, then plug it back up. It should work, my freezer worked but doesn't get cold. I read that it could be the relay. Hope I was helpful :)
#3 Posted : Saturday, November 7, 2009 3:54:41 AM(UTC)
Bad advice, I would just remove the back cover if it has one and check if the compressor is running. If not, you probably have a bad start device on the side of the compressor.Order AP2585092. Also, look in the back left side for the defrost timer and turn the shaft, just might be stuck in defrost. If so, order it AP2113785
