cmanesis
#1 Posted : Monday, May 4, 2009 3:37:53 PM(UTC)
cmanesis
Manufactured 07/2003. Sears Model #413.43142200, Serial Number XC33108599. When the washer fills it never stops and overflows to the point where it has pushed open the front load door. I have turned off the power and water still fills.
Thanks in advance for your feedback.
sidfink43
#2 Posted : Monday, May 4, 2009 4:10:37 PM(UTC)
sidfink43
Your most likely problem is the water inlet valve set, which will need to be replaced. This is a relatively inexpensive part, and you can reach them by removing the top of the washer.
Good luck, and let us know if this fixes the problem.
m_heydt@yahoo.com
#3 Posted : Friday, October 23, 2009 11:08:11 AM(UTC)
m_heydt@yahoo.com
Had similar problem. Turned out a mouse had eaten through the rubber sensing tube. The washer couldn't tell how full the washer was.:o
