broken02
#1 Posted : Friday, October 23, 2009 9:10:26 AM(UTC)
broken02
Help Please! I think this is a safety issue & subject to a recall. I purchased my Kenmore fridge with the freezer on the bottom 3 years ago. 2 days ago I opened the fridge and smelled plastic burning, the plastic cover for the inside lightbulbs was melting away. I thought maybe someone didn't close this fridge all the way, I took the cover off. Then the next night I went grocery shopping, The next morning I noticed everything that was higher up in the fridge was very warm, while things towards the bottom were cold. The lightbulbs inside the fridge never shut off and was constantly on causing the warmup. I took the extremely hot lightbulbs out & notice the lightbulb socket is brownish and that some of the plastic molding is also melted. Has this happened to anyone else? Any suggestions on what I need to have fixed? One thing I have noticed with this fridge is that when I have it open for a long period of time for cleaning the lights usually shut off by themselves without closing the doors.
magician59
#2 Posted : Friday, October 23, 2009 9:26:07 AM(UTC)
magician59
Put the light bulb(s) back in and open the door. Manually depress the light switch. If the light remains on, replace the switch. If it goes out, there is an alignment problem between the door and the switch.
broken02
#3 Posted : Friday, October 23, 2009 9:52:10 AM(UTC)
broken02
Thanks for your help, I put the lightbulb back in & the lights didn't shut off. What is the switch called or part# that I need to order?
magician59
#4 Posted : Friday, October 23, 2009 11:25:34 AM(UTC)
magician59
It looks like your machine was manufactured by LG. Unfortunately, I don't have access to parts descriptions. You may need to consult with your nearest Sears parts supplier for te replacement switch.
