Oven won't light, If I tap on the gas valve or turn a top burner on it will sometimes let the gas flow, and it will light. I switched igniter same thing I have two stoves I have tried both and changed out parts from 1 to the other and have same problems when it does lite and reaches temperature and when it calls for heat it wont ignite i have been working with these 2 stoves for awhile
The first thing I would do is call the Gas supply company to check the pressure in the gas line to the range.
Which parts did you exchange between your ranges?
Are they identical with the same model number?
