Chris64
#1 Posted : Thursday, October 22, 2009 7:06:29 PM(UTC)
Chris64
At 1st I thought it might be 1 of the bearings on the motor or the belt pulleys. After removing the access cover & inspecting, it is obvious that's not it. While down there, it is clear the noise is coming through the vent. I think I can fix it if you think you know what it might be & have the parts. Any help would be greatly appreciated....
Thanks in advance,
Chris
#2 Posted : Friday, October 23, 2009 4:11:56 AM(UTC)
Replacement parts for MAYTAG LDE4000ACW | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16000132.pdf
Check that something has not fallen into the blower wheel case.
Check the rear support rollers ror wear/slop. Also check that the shafts are OK.
Check the idler roller.
Would also check the front glides sometimes it is very difficult to isolate where the noise is coming from.
Also put some pressure in the direction the belt pull the motor's pulley and then try. Th endbells (rubber supports that hold the motor bearing centered) can wear out
Chris64
#3 Posted : Saturday, October 24, 2009 5:12:33 AM(UTC)
Chris64
Thanks for the quick reply. I went ahead & ran it later that evening after cleaning up inside that access cover & duct. It spit out a couple dozen pebbles/pea gravel, some more dust & dirt, and about 15 minutes later the noise stopped. Maybe all that stuff got shook loose while I was sliding the machine out of it's spot? I don't know, but I'll certainly hang onto your information.
Thanks again,
Chris
Guest (5)
