Washer machine will not stop filling up and over flows. I can suck or blow in the line going to the water level switch and hear it click but the water continues to run. Sounds like water level switch. What say you? Thanks.
If unplugging the washer doesn’t make the water stop the water valve is bad. If the water stops flowing when you unplug the washer either the tube that runs from the water level switch is clogged or the water level switch is bad. Hope this helps!Washer Repair Guide
