cant figure how to get the motor out, it will not run, does turn though!, also the electrical connectors, cant get them seperated, any ideas there thanks in advance, trying to learn!
You need to trouble shoot the dryer before deciding that the motor is the issue. Very often it is not. Your dryer has a number of safety thermostats and fuses which can be the problem. Also, I am not sure what you mean by electrical connections. Anyway, your dryer appears to be the Sears version of a Whirlpool Duet Dryer. Here is the service manual which will enable you to trouble shoot it and tear it down if you need to. https://secured.whirlpoo...64beaa/$FILE/Duetdry.pdf
