2 Pages<12
Palmer123
#11 Posted : Wednesday, October 21, 2009 4:11:27 PM(UTC)
Palmer123
Originally Posted by: glen65 Go to Quoted Post
If what I said earlier is the case then yes you would need to
replace the timer. But I would pay attention to what Frank has
to say also.
I have now replaced the Timer and the control switch on the Maytag Dryer model LDE712 and the problem still exists. The dryer will not shut off automatically, I have to open the door to make it stop.
Any more suggestions on what part it might be???:confused:
pdevinsky
#12 Posted : Thursday, January 13, 2011 9:39:58 PM(UTC)
pdevinsky
My problem which exhibited same issues as this thread, was that the linkage between the control switch and the chime actuator kept breaking. It looks like an extended paper clip. I've replaced that part for several years and it fixed problem.
NOW the piece that connected to the "linkage" on the control switch is broken and not sure if I need to replace the entire control switch.
Also if there is something I can do to prevent the linkage from breaking often I'd appreciate hearing about it. Thought perhaps the solenoid needed lubricant but then thought it would affect the magnetic pull.
Any advice is greatly appreciated.
Thanks,
Phil Devinsky
phil.devinsky@gmail.com
Maytag dryer runs continuously on timer and auto (Dryer Repair)
by s2zeller 10/12/2009 7:07:26 PM(UTC)
2 Pages<12
