wheelchair
#1 Posted : Monday, October 19, 2009 9:50:33 AM(UTC)
wheelchair
hi there. sorry I was so light on the particulars on the last post
I found the correct model number
When I set the temperature to delicate and the timer to a full cycle on delicate the drum turns good but I do not get any heat.
When I set the temperature to normal and the timer to full normal cycle the drum turns and I get heat however it is hard for me to tell if it is full heat
I hope this helps
rob
sidfink43
#2 Posted : Wednesday, October 21, 2009 9:01:57 AM(UTC)
sidfink43
I cannot get your model number to come up, but sounds like the first place you should look is your cycling thermostat.
jeffgalas
#3 Posted : Wednesday, October 21, 2009 11:38:27 AM(UTC)
jeffgalas
my model no. is mdg9206bww maytag gas dryer
my serial no is 40693680zs
replaced duct exhaust and cleaned lint complete
dry ignights but will not stay hot continues to tumle
jeffgalas
#4 Posted : Wednesday, October 21, 2009 2:37:34 PM(UTC)
jeffgalas
Sounds like the problem is a bad gas valve coils.
- The coil kit Part number: AP3094251
Kenmore dryer not heating properly (Dryer Repair)
by yyzt4e 7/8/2015 4:58:45 PM(UTC)
Estate Model Dryer not heating properly (Dryer Repair)
by eaaron63 7/28/2013 3:46:48 PM(UTC)
by Sangues 1/1/2013 2:31:57 PM(UTC)
Admiral gas dryer not heating properly (Dryer Repair)
by moonflower23 2/4/2012 10:35:54 AM(UTC)
by Rigdawg58 12/13/2011 1:59:35 PM(UTC)
by jjdm71 10/3/2011 11:12:52 AM(UTC)
by JaxMax 3/14/2011 9:11:16 AM(UTC)
by lp33852 5/28/2010 3:55:41 PM(UTC)
by mnova127 4/27/2010 7:35:53 PM(UTC)
Maytag dryer not heating properly (Dryer Repair)
by vpolitano 1/18/2010 9:37:23 PM(UTC)
