Mike Miller
#1 Posted : Monday, February 4, 2008 4:17:55 PM(UTC)
Mike Miller
Cold water fills fine, but Hot water will not fill at all but its trying (pump is pumping?). I have cleaned hoses and the screen at the water inlet valve. Still won't fill. What should be my next step?
#2 Posted : Tuesday, February 5, 2008 12:38:14 PM(UTC)
If there is nothing wrong with the hot water supply to the washer, then the problem is the water inlet valve (#805 on the cabinet break down diagram) or power to this valve.
Locate which of the coils is responsible for the hot water and check for 120V to this coil when the timer calls for hot water.
If there is 120V - replace the water inlet valve.
If there is no 120V - replace the timer.
- The part number for the water inlet valve is AP2618763
- The part number for the timer is AP2045768
Here are the break down diagrams for the GE washer Model WWA5800GAL
Mike Miller
#3 Posted : Tuesday, February 5, 2008 3:49:07 PM(UTC)
Mike Miller
The diagnosis is clear and I should be able to fix it. Thanks again.:D
#4 Posted : Tuesday, February 5, 2008 4:57:29 PM(UTC)
Mike,
Keep me updated, please.
GE Top Loading washer shuts off (Washer Repair)
by Mjrobert 8/10/2015 5:12:30 PM(UTC)
GE Top Loading Washer - Is this a bolted agitator? (Washer Repair)
by Plainswalker 5/9/2015 7:03:50 AM(UTC)
GE Top Loading Washer Extremely Noisy During Spin Cycle (Washer Repair)
by PaulTW 6/11/2012 1:33:33 PM(UTC)
GE Top loading washer won't drain (Washer Repair)
by jacoblag 1/21/2009 3:55:43 PM(UTC)
GE top loading washer not draining (Washer Repair)
by cpope24 7/3/2008 8:35:23 AM(UTC)
