FDAR
#1 Posted : Wednesday, October 21, 2009 10:45:39 AM(UTC)
FDAR
The dual burner on this unit works fine when using the large setting, but when using the small setting it appears to be on high no matter what the setting is on. Any and all help very much appreciated.
Mike
#2 Posted : Wednesday, October 21, 2009 1:36:45 PM(UTC)
Most likely the problem is a bad infinite switch for this burner.
- The dual burner infinite switch Part number: AP3189829
FDAR
#3 Posted : Thursday, October 22, 2009 5:37:25 AM(UTC)
FDAR
Gene,
Thank you for helping me so quickly, I will install new switch and let you know the results.
Mike
