Bamaman31
#1 Posted : Monday, October 19, 2009 10:14:36 AM(UTC)
Bamaman31
After washing machine goes into the Spin Cycle; it is still leaving our clothes soaking wet. I have read other similiar threads in different forums and some have recommended replacing the Clutch Assy. I have a part number of AP3094537 for the Clutch Assy I need for my Whirlpool washer. I wanted to see if this is the part I need or not. Also is there any link to a site that shows the replacement steps?
Thanks,
Rob
sidfink43
#2 Posted : Tuesday, October 20, 2009 3:33:34 PM(UTC)
sidfink43
If your clothes are coming out wet then either you have a blockage in the drain system, problems with the pump or the machine is not spinning fast enough.
You have the right part number to replace the clutch, but before you order it try to determine if the machine is draining appropriately. If it is, then if the spin is too slow it is probably the clutch.
This site will show you how to open it up and replace the clutch.
Clutch Replacement on Whirlpool and Kenmore Washers
Bamaman31
#3 Posted : Tuesday, October 20, 2009 4:02:42 PM(UTC)
Bamaman31
Thanks for your help Sidfink43!
jim greene
#4 Posted : Sunday, November 1, 2009 1:06:02 AM(UTC)
jim greene
washing machine won,t spin in spine cycle if have more than few pc,s of cloth,s in it.like, jeans it will wash everything but will only spin 1pr jeans, if but enymore into it it will wash them put want spin ,can only wash just few thing at a time ,it spins light loads fine not medium and no way a large load,have never work on washer dryers ect. is this something that maybe repair myself? Their is no drain problem use large load of water it drains just fine .
sidfink43
#5 Posted : Sunday, November 1, 2009 4:07:31 AM(UTC)
sidfink43
Jim
Please start a new thread with your full model number and I am sure someone can help you.
Spin cycle leaving clothes soaking wet (Washer Repair)
by ctrauthwein@hotmail.com 3/15/2010 5:20:14 PM(UTC)
