Rank:: Member
Whenever i try to set the cleaning cycle on my oven i get a series of beebs and then the word "DOOR" pops up on the screen and the cleaning cycle stops.
i checked to make sure there is nothing holding the door open (even a little) and try again but i get the same response. any ideas??
Originally Posted by: craig h Whenever i try to set the cleaning cycle on my oven i get a series of beebs and then the word "DOOR" pops up on the screen and the cleaning cycle stops.
i checked to make sure there is nothing holding the door open (even a little) and try again but i get the same response. any ideas?? I used the clean cycle last year and thought I would run it again. I select the run time and the display goes to dr, it never locks. How do I get to the motor? The lock motor is over a hundred dollars and it needs cleaning once a year. My wife spent two hundred dollars extra for a self cleaning oven. Rags and detergent.
