Hello, My dryer has aprox. 4 yrs of usage. It will turn on, tumble and heat but there is no airflow inside the drum or outside the exhaust duct with the hose removed. I have looked and there is no lint build up enough to cause a blockage anywhere. I have not taken it apart to investigate anyfurther yet because I was hoping you'd be able to advise me on what to check when i do.:confused: I would like to fix this issue myself as (even though a woman) i am confident in my ablity to do this with just a bit of assistance from this forum. Thank you Lynn
Check that the blower wheel is still attached to the motor's shaft. |
THIS FORUM IS DEAD!!!!!!! |
