afeuquay001
#1 Posted : Sunday, October 18, 2009 6:42:45 AM(UTC)
afeuquay001
Washer will not drain out water. I have replaced pump and checked all hoses. What is next?:confused:
sidfink43
#2 Posted : Monday, October 19, 2009 9:34:47 AM(UTC)
sidfink43
You need to see if you are getting 120v to the pump when the timer is in drain position.
If you are, then your replacement pump is also defective, which is unlikely or you have some blockage you have not yet found.
If you are not, and I suspect that will be the case the problem is either in the lid lock assembly or the timer. By pass the lid lock assembly, and try it, if you do not get power also then the problem is likely in the timer.
Good luck.
