washerhelp2
#1 Posted : Saturday, October 17, 2009 8:39:02 AM(UTC)
washerhelp2
My machine tub leans to one side slightly and does not spin to its full capacity. I was previously told that it most lightly is a support or support spring. What is the best way to enter the machine to check this? Form the top or from the back?
applianceman
#2 Posted : Saturday, October 17, 2009 12:51:28 PM(UTC)
applianceman
You remove the entire case. This is easy first remove the covers off each end of the control panel to access the screws that holds the control panel in place (you may not have to do this). Then hinge the control panel up. Once done you should see two brass colored clips, remove them. The lid-switch-wires come up through the case in the center, unplug them. Once done you should be able to remove the entire case out from around the washer to check for a loose spring. For more on this along with some pictures use this link Whirlpool Washer Disassembly Guide
